Can I add cleaner into the water tank when moppings?
We do not recommend adding cleaner into the water tank as bubbles created by the cleaner may block the filter. The you choose to use cleaner, you do so at your own risk.
Related FAQs:
Will I receive an alert when the water tank is empty?
What should I do when there is little water leaking from tank and mopping cloth is almost dry?
Was this article helpful?
69 out of 85 found this helpful
