How do I restore my robot cleaner to factory default?
We suggest you restore device to factory default.
Step 2. Use a pin to press the reset button next to wifi LED just once,and power button, home button and spot cleaning button's light will be out. When you are doing this, please make sure home button is still under your finger's holding without moving.
Notice:
Was this article helpful?
10 out of 20 found this helpful
