Roborock S5 No-Go Zones and Virtual Walls Tutorial
Open your Mi Home app and tap on S5
Tap the... in the top right corner then tap Vacuum Settings and turn on Map Saving.
If Map Saving is already on, you can skip this step.
Return to the Map screen
Tap Edit Map then tap "No Go Zone"
Add a Zone, move it where you want it, and adjust its size.
You can add up to 10 No Go Zones.
Add a Virtual Wall, move it where you want it and adjust its size.
Tap Save in the bottom.
Tap Clean to start cleanup.
Was this article helpful?
188 out of 590 found this helpful
