What are the differences between Roborock Qrevo Master and Qrevo?
①. The maximum suction power of Qrevo Master is 10000Pa, significantly higher than Qrevo's maximum of 5500Pa.
②. Qrevo Master comes with a DuoRoller Riser™Brush, which improves cleaning efficiency over Qrevo's single main brush. Moreover, both the main brushes and mop modules of Qrevo Master are designed to be liftable, whereas Qrevo only features a mop lifting.
③. Qrevo Master features an 80ml built-in water tank, a 4L clean water tank, and a 3.5L dirty water tank. In comparison, Qrevo also boasts the same 80ml built-in capacity, along with a larger 5L clean water tank and a 4.2L dirty water tank.
④. Qrevo Master includes Roborock Smart Plan, which automatically adjusts cleaning modes based on the home environment and past cleaning habits, unlike Qrevo.
⑤. Qrevo Master offers additional features such as "Add Area" for targeted re-cleaning and "Skip Area" to bypass specific areas for efficiency, neither of which are available on Qrevo.
⑥. There is a heating module inside Qrevo Master's dock to heat water in the clean tray to 60℃. With 60℃ hot water, most greasy dirt can be dissolved, such as beef tallow, mutton tallow, starch, etc., while Qrevo only uses room temperature water to wash the mops.
⑦. Qrevo Master features an Intelligent Voice Assistant and remote viewing capability, which Qrevo lacks.
⑧. Qrevo Master supports dirty area detection and smart re-mopping features, unlike Qrevo.
Was this article helpful?
96 out of 131 found this helpful
