For reset Roborock S5 :
Step 1. Hold the recharge button for 3-5 seconds.
Step 2. Use a pin to press the reset button next to wifi LED just once,and power button, recharge and spot cleaning button's light will be out. When you are doing this, please make sure recharge button is still under your finger's holding without moving.
Step 3. Keep holding recharge button for 5 seconds after you press reset button until power button blinks again and you hear the tone restore, and then you could remove the finger.
Notice:
Related FAQ:
Was this article helpful?
866 out of 2413 found this helpful
