What are the differences between Qrevo Master and Qrevo Curv?
1. The maximum suction power of Qrevo Curv is 18500Pa, significantly higher than Qrevo Master's maximum of 10000Pa.
2. Qrevo Curv comes with a DuoDivide Brush, FlexiArm Arm Side Brush and liftable omnidirectional wheel to achieve 0% hair entanglement, whereas Qrevo Master lacks.
3. Qrevo Curv is equipped with an advanced smart liftable chassis system, the two main wheels and omnidirectional wheel's versatile combinations enable easy obstacle overcome in complex environments like over door threshold, sunken floors, medium-pile carpets, and around furniture, boosting cleaning efficiency, whereas Qrevo Master lacks.
4. Qrevo Curv allows users to remove specific areas directly from the app, a feature not available on Qrevo Master.
5. There is a heating module inside Qrevo Curv's dock to heat water in the clean tray to 75℃. With 75℃ hot water, most greasy dirt can be dissolved, while Qrevo Master only uses up to 60℃ hot water to wash the mops.
Was this article helpful?
77 out of 106 found this helpful
