What are the key features of F25?
Suction Power: 20,000 Pa – Delivers strong suction for thorough cleaning on various surfaces.
Height when Flat: 4.92 in / 12.5 cm – The vacuum can be laid flat to clean under furniture and appliances, ensuring deeper cleaning in hard-to-reach space.
Self-washing and drying temperature: 90°C.
Dual Scrapers: Constant-pressure floating scraper + Anti-entangling comb scraper – The dual scraper is designed for picking up hair and preventing it from tangling in the roller.
Roller System: Single + Edge Cleaning (both sides 1 mm).
Dirt Detection: Yes – The DirTect module detects the level of dust during cleaning and adjusts the mode. It also determines the optimal self-cleaning intensity after you place the cleaner on the charging dock.
Water Tank Volume: The clean water tank holds 870 ml and the dirty water tank 720 ml.
Run Time: 40 minutes (Auto Mode) – Offers a long run time to clean large areas without interruptions.
Drying Time: 5/20 minutes – Offers 5-minute fast drying mode and 20-minute quiet drying mode. They deliver the same drying efficiency, with the only difference in noise level and drying duration.
Was this article helpful?
51 out of 80 found this helpful
