What are the key features of F25 ACE?
Suction Power: 20,000 Pa – Delivers strong suction for thorough cleaning on various surfaces.
Height when Flat: 4.92 in / 12.5 cm – The vacuum can be laid flat to clean under furniture and appliances, ensuring deeper cleaning in hard-to-reach space.
Self-washing and drying temperature: 90°C.
Dual Scrapers: Constant-pressure floating scraper + Anti-entangling comb scraper – The dual scraper is designed for picking up hair and preventing it from tangling in the roller.
Roller System: Single + Edge Cleaning (both sides 1 mm).
Dirt Detection: Yes – The DirTect module detects the level of dust during cleaning and adjusts the mode. It also determines the optimal self-cleaning intensity after you place the cleaner on the charging dock.
App Control: Yes – Allows remote control and customized cleaning via the app for enhanced convenience.
Auto Detergent Dispenser: Yes – Enjoy up to 30 days of cleaning with a single detergent refill, as the auto dispenser precisely releases detergent as needed.
Water Tank Volume: The clean water tank holds 740 ml, the dispenser 100ml, and the dirty water tank 720 ml.
Run Time: 40 minutes (Auto Mode) – Offers a long run time to clean large areas without interruptions.
Drying Time: 5/20 minutes – Offers 5-minute fast drying mode and 20-minute quiet drying mode. They deliver the same drying efficiency, with the only difference in noise level and drying duration.
Adaptive drive wheels: Yes – Features adaptive drive wheels for smooth movement and easy maneuvering during operation.
Was this article helpful?
120 out of 162 found this helpful
