What’s the difference between Standard Mop Route and Deep Mop Route?
The following applies to S7, S7MaxV, S7Max Ultra, S8, S8+, S8 Pro Ultra and Q Revo only.
If you select Standard Mop Route, both suction power and mop intensity can be fine-tuned, making it ideal for regular uses. Deep Mop Route is designed to provide best mopping performance. If the Deep Route is selected, suction power will be minimized, while the scrub intensity is still selectable. The Z-shape path will be almost twice denser than that of the Standard Mop Route, so the cleanup will take longer. It’s recommended to use mild or moderate scrub intensity if you’re using Deep Route.
Was this article helpful?
1021 out of 1287 found this helpful
