What should I do when error 13 occurs?
1. If there're some stains or rust on the charging contacts on the dock or underneath of the robot, please use a piece of cloth moistened with alcohol solution or an eraser to remove them. See attached picture "charging contact".
2. Please check if the dock charger is working or not.
The indicator light on top of the dock should be solid on without the robot and off with the robot placed on it. See attached picture.
Kindly double check if the cable and the slot of the dock are well connected.
Please push the cable head into the slot at bottom of the dock very hard. See the video below.
3. Please unplug the charging dock, and leave it there for about 2 minutes. Then please re-plug it and try again.
Related Troubleshootings:
Roborock Error 1
Roborock Error 10
Roborock Error 18
Roborock Error 8
Roborock Internal Error
Roborock Error 9
Roborock Error 5
Roborock Error 4
Roborock Error 7
Was this article helpful?
99 out of 954 found this helpful
