What should I do when there is little water leaking from tank and mopping cloth is almost dry?
  1. Change the mop cloth and water filters then try again.
  2. Do not use cleaning products in the water as this may block the filter.
  3. Use a needle to gently clean the water outlet.
  4. Put the water tank on a flat surface and look for bending.
  5. A bent water tank will need to be replaced.
Related FAQs:
Will I receive an alert when the water tank is empty?
Can I add cleaner into the water tank when moppings?
Was this article helpful?
168 out of 1038 found this helpful
