What should I do when the robot cleaner makes noise?
Try each of the following steps until the noise stops. After each step, run the robot briefly to see if the noise continues. If not re-install the part and move on to the next step until the noise stops. If the noise stops, clean the part thoroughly then reinstall it and try again.
- Remove the main brush and brush cover
- Unscrew and remove the side brush
- Uninstall the front wheel (keeping the front of the robot supported)
If the noise ceases when the front wheel is removed, after cleaning, pour no more than two drops of olive oil down the wheel shaft and rotate it to spread the oil before reinstallation.
If none of the above have stopped the noise, turn the driving wheels manually. If they are, the source of the noise, contact your Roborock dealer for further support.
Was this article helpful?
563 out of 1887 found this helpful
