What should I do if the Auto Empty Dock is not emptying effectively?
  1. Check if you are using the auto-empty dustbin, not the standard dustbin.
  2. Check if the plate covering the air inlet next to the auto-empty dustbin has been removed.
  3. Check that the main brush cover has been properly attached.
    Turn your robot over and remove the brush cover to see the installation slots.
    Re-insert the brush cover, making sure to place the tabs in the slots.
    When properly installed, all four tabs should be hidden.
  4. Check if the dust inlet is blocked or not.
  5. Turn over the Auto-Empty Dock, and check if the air duct is blocked or not.
Was this article helpful?
213 out of 1614 found this helpful
