How to create multiple maps for multi-level house?
  1. Map saved mode is enabled;
  2. Robot starts from dock;
  1. Robot goes everywhere on map it detects to clean, not just somewhere. Please make sure the doors are open for the rooms you want to be displayed on map.
  1. Robot returns to dock(whose position is not moved) by itself and successfully.
Note: It applies to S4, S4Max, S5 Max, S6, S6 Pure, S6 MaxV,S7, S7maxV, S8, S8+ S8 Pro Ultra, Q Revo, Q8Max, and Q5 Pro, which support multi-floor maps feature. (Take a quiz to know which Roborock for you)
Related FAQs:
Can I make the robot cleaner clean specific rooms?
What should I do when the map is in a wrong angle?
Was this article helpful?
2655 out of 3668 found this helpful
